1 - 10 of 10 Posts
2005 ML350 SE Black
Could anyone help me in finding a cleaner that I can use in the engine compartment to remove the normal dust, dirt and oil that accumulates over time. I little nervous of spraying it down with GUNK and hosing off the engine
thanks
2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
I've never used it myself; but I understand a lot of members have had great success with a product called 'Simple Green'.
2005 ML350 SE Black
Thanks ...familiar with the product, will give it a try. FAR888 what do you do to keep it clean just wipe it down ??
1999 ML320 Elegance, BMW R1150RT, SAAB 9-3
i use car wash soap -you know the same stuff you use to wash your car ... with water of course in normal proportions,
wipe with brush or rag & use small pump bottle (ex empty windex bottle) of water for a nice gentle misting rince - not a hose. go light on the fluids and the forces...
gets rid of most dirt/filth but if you want perfection (i.e like new) you will be disappointed. there is a detailing forum here - you might check what they have to say...
03 ML350
I'd use Gunk Foaming Engine Brite before Simple Green. It's safe for paint and plastic. Simple Green will spot aluminum - read the label. There are orange based cleaners that work very well but they are pricey.
I do much like Unhofliche_Gesundheit does in post #4.
It's not perfection but it gets pretty clean.:)
2001 Mercedes ML55 AMG (Silver)
Go with one of gunk or over the counter engine degreasers, I like the gunk foamy brite. Then Get CD2 Engine Detailer. ITs a protectant that can be sprayed over any engine service, metals, plastics, etc. I spray everything pretty good then wipe all the plastics down. It leaves the Engine Compartment looking shiny and clean. I love it. You can find CD2 at autozone or pep boys. Its real good stuff and lasts a while. BE sure to wrap any exposed wiring harnesses, the coil, the battery terminals in plastic wrap, or I like to use aluminum foil, since its so easy to put on. Just watch it on the bettery cause you can short the terminals if your not careful. Wrap everything up before you apply the degreaser cause you have to rinse the degreasers with the hose and you dont wanna soak any electronics, although if they get a little water on them its not the worst thing, you just dont want them soaked in water. I follow this procedure and degreaser and protect the engine compartment about 2x a year. I also do behind the grill and by the radiator and anything else that is exposed. I also like to use a light brush to go over everything i can get onto to loosen any heavy grime and grease. Nothing crazy just a quick once over the hoses, plastics, wires and block. Then I rinse and protect. It gives the truck a nice finished detailed look.
2004 SL500; 2003 E320; 2001 ML430 Sport; 1999 E320 Wagon
As FAR mentioned, I have had very good luck with Simple Green. The procedure is simple as well. 1st I cut the stuff to 50/50 with water. Spray it on a cold engine on a warm or hot day and let it sit - but do NOT let it dry. The ambient temperature seems to help it work, so a cold engine on a cold day does not work as well. Re-coat the really dirty areas as necessary. After several minutes, hose it off good with a garden hose. You do not need to go all out and cover the electrical components and wires. The engine is made to get wet occasionally, just don't spray anything directly into the air intake or directly spray the electrical boxes (fuse box, computer box). Pretty much everything else is fair game. After the car drains for a while I start it up and get it to normal operating temps via a drive around town. The regular engine heat steams away the water and residual cleaner from where you don't want it. Finally hit the moving parts with some appropriate lubricants.
I have been doing this for decades now with all kinds of cars and none of them has ever failed to start after a cleaning IF you start it right away after the cleaning and then get it warm. The engine is a lot more pleasant to work on when it's not covering you with grime at the same time.
1 - 10 of 10 Posts
