1 - 9 of 9 Posts
1991 Mercedes Benz 300SL
HELP!
I have a 1991 300SL with 90K on the odometer. It runs great EXCEPT...
in hot weather (about 80 degrees or more), from a standing start, when attempting to accelerate the engine seems like its going to stall. The car barely moves at all. After a few sputters, it starts up. Once its going there is no problem that I have noticed. It seems like a fuel issue...maybe.
I can't figure out why this would happen in hot weather only...the car runs great in the winter! Does that make any sense?
Does anyone have any ideas? Thanks.
CBJ
Hello CBJ,
Welcome to the forum
When is the last time you had a tune-up? Spark plugs, fuel injetcion service, transmission service, etc?
All done very recently {2 months}. In fact, I thought that fixed the problem...until Thursday!
Greek God of the R129
SL500-500SEL-190E
You can't easily vapor lock a fuel injected car, the fuel is moving to fast unlels you run the fuel line on the exaust it would not happen.
You have the a/c on, so you are pulling a load on the engine.
I don't know if your car has an speed sensor on the a/c compressor.
Most likely it does, check it.
Look for the idle adjusing valve sticking or not geting the proper signal.
Regards.
aam.
PS.
Besides the fuel line is going through the a/c for additional cooling.
German engineering. ;)
'90 R129 300SL-24, 94 C140 CL500, '92 W140 400SE,'98 W210 E300TD
Hi there,
I'd go with either the IAV (idle valve) or coolant temperature sensor. I had a very similar problem on a W126 300SE (which has the same M103 engine) that I sold last year. Cleaned the IAV, replaced the sensor (located in cylinder head near bulkhead/firewall) and car ran like a dream.
Hope this helps.
Best Regards,
Mark.
Outstanding Contributor
2003 SL500, 2003 SL55, and four R129s
I would check the ignition and injection systems for fault codes. If that found nothing, I would follow the electrical test procedures from the engine diagnostic manuals found in the R129 Tech DVD and the WIS.
1 - 9 of 9 Posts
