Administratoris Emeritus
2021 SL770
Why are you punishing members with this interminable nag screen that pops up each time I login and won't go away? Are you trying to drive members away, 'cause I suspect it's working?
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
I'm running into that as well.
Administrator
Mercedes c350
This should be resolved. If it is not it may be a bad cookie. Please clear your cache and cookies, and dismiss the pop up once by hitting "not now". From there you shouldn't see this issue again.
Let me know if that's accurate to your experience.
-Gerrit
R/C107 Moderator
-Gerrit
Get rid of it on your end. Why should we have to do anything to address the problem(s) you created?
Administrator
Mercedes c350
We are working on making some updates to the way the push notification works.
Currently, it is based upon your cookies/session but we are looking to update it based upon the user profile.
Jeff M
