Hello, if any of you have been following my Thread "Theirs a New One Coming", you will notice I'm working on an Arduino based controller for a PWM radiator fan. One of the challenges I have come up against is getting the fan to run a predetermined amount of time after engine shut down. I was trying to do this in code and control it using the Arduino but I was finding the code very difficult and also required running the Arduino at all times including with the key off and out of the car. So I am revisiting a hardware solution and trying to implement a 555 IC for a time delay after shut down.
The problem is all of the examples I have seen on how to do this involve grounding pin 2 of the IC to make this happen. I need to do something different. I need to activate the timer when power is removed form the system as in I turned the key off. I prefer to keep hardware down to a minimum and would like to avoid installing a relay if possible. I'm also not set on the 555, but its the only solution I have found so far.
If anyone has a solution to this it would be appreciated.
elonics.org
Adjustable Auto On Off Delay Timer Circuit Using 555 IC
A tutorial on how to make an adjustable delay timer circuit using 555 IC that can automatically turn on/off any output after a fixed duration. This electronic timer circuit is helpful when you need to power On/Off any AC Appliances after a pre-defined duration.
