1 - 1 of 1 Posts
2001 M-B E320 (W210)
Below is a picture of a wire that has either been cut or maybe was never used; it's in the foreground, coming out of the wiring harness and is a solid, light-purple color. There is no end cap and the exposed end is not wrapped. In the background you see a similar colored-wire but it is attached to a black wire by way of a connector.
Any idea what the wire in the foreground might be, and should it be capped off if not in use? What is the black box called?
Thank you
1 - 1 of 1 Posts
