Courtesy of;Steve 019<br>
Hope this help.<br>
With the door panel off, locate the terminal block that the motor wires go to. Disconnect the wires and use a battery charger to checck the motor. just reverse polarity for up and down. If you r window doesn't move in one direction, listen for the motor noise. I hope this will help isolate the problem. On my model the console switch will not operate if the door switch is bad or not installed.
Hope this help.<br>
