Hi all,
I hope you can help me decide. About 1 year ago I had to replace the window regulator because the windows wouldn't go all the way up. Two months later, the alarm started going off in the middle of the night for no reason. Few days later, when driving, I noticed the seat belt blinking light above the rear view mirror was constantly blinking while driving, few days after that, the fuse C kept blowing up. The was blowing up when opening the door. I drove the car without replacing the fuse C which meant I kept the car unlocked. Another couple of weeks went by and my mother drove the car to visit a friend and the car would start at all when she was planning to return. We had to tow the truck to a local mechanic, The mechanic spent about 6 hours and they had to unplug and plug every wire. Somehow they made the car run again, but I noticed that fuse C was replaced by higher fuse (25amp) instead of 16 which should be the right amp...Since then, the car has stalled 2 times while driving (about two months apart). I brought the car the Mercedes dealer to run electrical diagnostics and the computer showed no fault codes. When the car stalled again, I brought the car again to the dealer and they kept the car for 6 days and ran a test every morning. They couldn't find anything. I want to note that when the car stalled, it happened during the first 5 minutes while driving. The dealer changed the fuse C to correct number which is (16amp). The fuse is not blowing up. I decided to take the car to a local independent Mercedes mechanic. He says that I should replace Wire Harness. Should I do it. The Mercedes dealer said that the harness is not that bad small cracks. Note that the car is 1994 and the mileage is only 64k.
I appreciate your help...
Thank you...
Thank you...
