1997 E200 kompressor
Hi I had this problem for over a year when it rains or when i wash the car water gets in somewhere and makes problem with the windows,central locking,window wiper, blinkers stuff like that, when I take the battery off and put it back on it resets and works, but now it didn't fix it before if i held the lock on the key all the windows didn't close now the do but i cannot lock or unlock the car.
If someone have any ideas where the wiring goes thru i checked in the hood all fuses and wires the boxes are good no water there so it must be inside of the car somewhere if someone has nay idea where the wiring goes for the windows,centrallocking stuff like that pls help.
w210 1997 e200 kompressor EU
1998 E320 base sedan @ 160kmiles
Check under the rear seat where the battery is for water contamination.
Check the passenger side floor (close to the door sill) for water contamination.
Check inside the module box for water contamination (the CCM module).
