I drove about 100 miles last week to pick up a friend at the airport, let the car sit 20 minutes, and then wouldn't start when I came out (there was a little battery left, but not enough to crank the starter). I checked and had not left the headlights on. The only unusual phenomenon on the drive down was that the radio, turn signals, heat and other dashboard electrics would turn off intermittently, then come back on. Since then the car has started fine twice, but today I experienced the same symptoms as the airport drive, needing a jump twice. I turned the car off after a 30 minute drive, then immediately tried to restart it, but there was hardly any battery left and it wouldn't start. I suppose the alternator should be suspected, but the car has not overheated and the battery idiot light hasn't come on. The only thing I've done is put in a new battery six weeks ago.
I thought I would solicit your opinions before taking the car for professional attention.
Thanks,
Brian
Thanks,
Brian
