recently installed a new rear view element(glass only)same plug same pins and number of pins in plug, after starting the vehicle noticed all engine instruments were not registering, speed,tach,oil press.,fuel quantity,water temp,mpg. Clock is functioning along with all a/c and radio functions.ckecked fuses and none blown.This is a 1997 S500 with 156,000 miles, no other problems at all.
Can anyone suggest the next step?
1997 S500V, 1999 S500 grand edition, 2006 s65 amg
My bad for the late reply but the rear fuse box is on the right side of the trunk. And the coffin box is under hood on the passenger side where all of the modules are and there is a module with about 4 fuses you need to check that too
if you have the radio code you can try to remove the negative wire off the battery for 10minutes and reconnect it. but the mirror doesn't have anything to do with cluster unless it throws a fuse.
