1976 W116 - 280S / 1994 W140 - S320
Hi everyone,
I only use my 1993/4 S320 as a weekend leisure runabout. Last weekend the aerial and CD wouldn't work properly, after inserting the key nothing happened, I pulled the fuse - OK, replaced it and still nothing (?). After about10 minutes driving the aerial and CD started up again, and continued to work properly for the rest of the day. I have decided to use the car for a couple of ays this weeks, I commute about 100 miles a day. This morning there were no issues. My radio doesn't work nor does the cassette deck, could that be causing an issue?
94 s420 250kmiles
the radio signal booster is going bad, same thing happened to my car its the silver box attached to the power antenna, if you unplug the blue wire to it everything should work again but you will lose some signal power
Thank you for that information. Could I get a replacement part? I'd like to keep the car as original as possible.
