Mercedes S430
2000 S430.. having issue with the ignition key not turning:crybaby2:
question is.... if I replace the EIS unit from other used MB. Can MB dealer program it with the "orange Key"...?
Or i need to buy brand new EIS?
You could ask from the W220 forum but I would say "no" anyway, an official dealer would not (be able to) program a used EIS to another car.
You might be able to find a used part that has been programmed virgin, then the dealer might code it (if they accept parts from the customer, that may not be the case with theft relevant parts).
Outstanding Contributor Always Remembered RIP
216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
On this car the EIS , steering lock and engine are all coded together, they cannot be re coded
How many keys do you have, if only 1 the transponder coil may have fallen off
Zotye Auto 1.5T T600 2016
How do you know it is the EIS, have you had any diagnostics done? And no a used EIS cannot be recoded.
Mercedes S430
Key was not turning, so i towed the car to MB dealer for Diagnostic.... turns out bad EIS..400$
W220 2003 Update S500L, W204 2008 C220 CDI
