1 - 1 of 1 Posts
hi I just replaced the pipes going to and from the LP fuel pump, during the op time got tight so it was put into a garage, to reassemble mostly. anyway to get to the garage i had to tow it which meant replacing the battery (as it has needed a charge) so i had lights ETC. what I`m thinking is the MAF and filter sensor (diesel) were disconnected when I towed it/reconnected the battery.
would this be enough to enable limp mode ?
any thoughts would be great
1 - 1 of 1 Posts
