· Moderator
1998 SLK 230
here is a vid showing a person dynoing their car (not my car). doing an ECU flash AND pulley make a difference to HP. and yes it was done on the same day
this is for the 4cyl M111 motor (slk 230)
run 1 with ASP pulley ONLY
run 2 with ASP pulley + ECU flash
and its a reasonable gain at that... 20hp at the wheels
99 SLK 200 K (M111.943, Eaton M62, 5 Speed Manual) SL55 AMG look, 18'' AMG style 4
160 Hp on the wheels with ASP pulley only? it is low
on the other hand +20hp for M111 on the wheels from software seems high
software supplier?
· Moderator
1998 SLK 230
It's a dyno dynamics dyno they read low. 160hp at the wheels is about 220hp at the engine.. And 180hp is about 240hp at the motor.
2001 SLK 230 - 6 on the floor
Was there a run before any mods??
Presuming pulley change could be done after a base line run and pulley change and ECU flash then done withing the day - doesn't sound unreasonable to me
· Moderator
1998 SLK 230
Discussion Starter · #5 ·
can email the guy and ask... dyno dynamics dynos usually have big losses and read low. dynojet dyno would read 180hp at around 202hp at the wheels which is still about 240hp at the crank (16% loss).
point is cant compare dynos to dynos, they are only a tool to see if what you have done has increased power or decreased etc... in this instance there was a gain by doing an ECU flash.
according to his description OE tuning did the work
'00 slk230k (engine swap), '75 300D, 2011 GTI
subby is 100% right on this... if you guys remember when I did my dyno, I only got in the 180s for wheel horsepower but everyone there that day knew the dyno was reading extremely low, even though I have quite a lot of mods done
C 230 Kompressor Sport Edition
160hp with ASP pulley seems low to me-my W202 C230 Kompressor M111 did that much yesterday on a dyno without ASP pulley and the dyno was reading really low because new Audi S5’s were in mid 200’s and V8 S4’s manual tranny were low 200’s.
