1 - 10 of 10 Posts
2012 SLS AMG
Click HERE to order or for more information.
Starting At – $16.02*
A common part failure on Mercedes-Benz 722.6xx automatic transmissions, the wiring harness connector can begin to leak transmission fluid, eventually draining to the transmission control module and causing expensive damage.
ECS Tuning offers a brand new Wiring Harness Connector Kit, complete with new o-rings, dipstick tube cap lock pin and a quart of fluid to make installation a quick and easy process.
Fits:
E320 (2003-2006)
E350 (2006-2009)
E500 (2003-2006)
E550 (2007-2009)
E55 AMG (2003-2006)
*Model Years 2007-2009 Only Applies To 4Matic Vehicles
*Price subject to change.
2012 SLS AMG
Discussion Starter #2
:: ECS Tuning :: 722.6 Transmission Wiring Connector Kit For Your W203 C-Class
Fits:
C230 (2002-2005)
C240 (2001-2005)
C280 (2006-2007)
C320 (2001-2005)
C350 (2006-2007)
C32 AMG (2002-2004)
C55 AMG (2005-2006)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Wiring Connector Kit For Your W209 CLK-Class
Fits:
CLK320 (2003-2005)
CLK500 (2003-2004)
CLK55 AMG (2003-2006)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Wiring Connector Kit For Your R170 SLK-Class
Fits:
SLK230 (1999-2004)
SLK320 (2001-2004)
SLK32 AMG (2002-2004)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Wiring Connector Kit For Your R129 SL-Class
Fits:
SL320 (1997)
SL500 (1996-2002)
SL600 (1996-2002)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Wiring Connector Kit For Your W208 CLK-Class
Fits:
CLK320 (1998-2003)
CLK430 (1999-2003)
CLK55 AMG (2001-2002)
**2003 Model Year is For Convertibles Only**
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Service Kits For Your W215 CL-Class
Starting At – $81.41*
Your Mercedes-Benz transmission is a collection of parts that must each be functionally sound for the gearbox to do its job.
It follows then, logically, that when attending to a particular transmission issue, the strength of the weakest part determines the end quality of the system.
For this reason, ECS offers several complete Transmission Service Kits for your Mercedes.
Choose from premium ECS-assembled and genuine OEM packages - each including Automatic Transmission Fluid, Filter, Oil Pan Drain Plug and Sealing Washer, Dipstick Tube Cap Lock Pin, and Pan Gasket.
Fits:
CL500 (2000-2003)
CL600 (2001-2006)
CL55 AMG (2001-2006)
CL65 AMG (2005-2006)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Service Kits For Your W202 C-Class
Fits:
C230 (1997-2000)
C280 (1997-2000)
C36 AMG (1997)
C43 AMG (1998-2000)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Service Kits For Your W140 S-Class
Fits:
S320 (1997-1999)
S420 (1996-1999)
S500 (1996-1999)
S600 (1996-1999)
2012 SLS AMG
:: ECS Tuning :: 722.6 Transmission Service Kits For Your R230 SL-Class
Fits:
SL500 (2003)
SL600 (2004-2009)
SL55 AMG (2003-2008)
SL65 AMG (2005-2009)
1 - 10 of 10 Posts
