Does anyone know of a good troubleshooting guide/pictorial (like dieselgeek has for the later system) for the early glowplug system? In this case, a '79 300TD, 18mm loop type plugs with the relay under the dash?
Also, does anyone know of a source for an 18mm glow plug reamer that does not cost the earth? Or perhaps a place that will rent one?
I plan to upgrade to the pencil-type fast-glow system, but I want to make sure the exisitng system is working correctly before I start changng things. I currently have an intermittent indicator light issue.
Thanks!
-Kevin
'79 300TD 120K
Thanks!
-Kevin
'79 300TD 120K
