'99 E55
I have a '99 E55 that I recently put H&R springs and Bilstein's on. The car has some serious negative camber (1.5 - 2.0 degrees) and I've eaten my tires rapidly (as I knew would happen).
Does anyone have experience with a camber kit to minimize the negative camber? Is there a factory kit available?
Currently, my front tires will hit the plastics inside the fenders if I hit a rut or take a full-lock turn with 2-3 passengers.
If I add a camber kit, will I bottom out on the plastics more frequently?
Any help or suggestions are appreciated:)
W211/W210 Estate /W209/W208
Do a search on Camber kits..K Mac makes one
Also a Member on MB world makes some arms that are adjustable...looks great!a lot less dough!
I have H/R springs with 1bump spring pads on my W210
and Used the K mac kit...Great results
A little neg camber is Good! for handling
