1 - 16 of 16 Posts
2003 ML500 & 2006 C230
This car is in the Philippines VIN#11998512008006E110 car is a E440 what car is this the equivalent of, I need to get a couple ignition coils for it. Any & all info I can get on this car will be greatly appreciated.
Thanks in advance Geoff
W124 Moderator
Geoff
There wasn't ever a E440 model produced for the W124 chassis. Is the engine in this car an inline 6, V8 or V6?
Jayare
Sent from my SM-A515U using Tapatalk
Geoff
Jayare
You see I really don’t know that much about the car but it is a V8 & it’s model designation includes the words Avant Garde E440 I’m just trying to figure it out also not even sure if that’s the VIN
Here’s more info the number I posted before was the engine number
VIN WBD2100721A209603
W124 Moderator
The car is an E420, M119 V8. There two coils.
Jayare
Using this vin can you say for sure which chassis designation this vehicle is? VIN WBD2100721A209603
registration says its a 2003 but even as a E430 it does show in the 2003MY string more like a 2002 E430 but no where can I find a 2003 E440 Avant Garde
W124 Moderator
Post up a picture of the car.
1990 Benz 300E 2.6 (mine) ; 1994 E320 Wagon (wife's) ; 1993 300CE Cabrio, needs some TLC
again, its an E420, not E430 or E440... ... Model 210.072 from your VIN, with engine 119.980 (4.2L DOHC V8) No data card on file with Mercedes. 'avante garde' is just an interior trim/color package.
per the mercedes parts catalog, a engine 119.980 use 'coil over' ignition, each spark plug has its own coil. there are M119 4.2L V8's that have 2 4-way distributors each with its own coil, but the XENTRY Parts Information system says yours is coil-over. 8 separate coils, PN A0001587203, each with a 'cable connector' A0001594142 between the coil and the plug, and held in place with bracket A1191580740
Discussion Starter #12
WOW Awesome thank you so much! I’m really at a loss with is car being 10K+ away & a pandemic it’s been a struggle but big thanks to you all.
btw, due to sufficient confusion with the M119 engines having two ignition configurations, you should have someone check to see if it has the 2 distributors, and if so then it would have two separate coils, whereass if it doesn't have any distributors, then it has the 8 coil-over-spark ignition ...
Discussion Starter #15
I'm trying to get someone to do a facetime walkaround with me on the phone so i can really see whats going on
1 - 16 of 16 Posts
