Hi all,
I am new to this forum and to the 97 E420. The problem is the sunroof stopped sliding open, it will pop up and slide closed if I manually crank it open then close it with switch. I read on here how to sync it and that worked 2 times then stopped sliding open again and resyncing doesn't help again. I manually cranked it open then removed the switch and used the key to close all windows and roof, but when I use the key in the door to open all windows and roof, only windows open. I have done this with switch connected and disconnected. So I am stumped, I don't think it is the switch or motor. Is there something else I am not looking at. I have tried to find a wiring Diagram online, but have not had luck. Thanks
