Using a MityVac extractor, the most I can get out is 6 qts, yet my dealer consistently charges me for 8 quarts. Any comments, suggestions, advice?/ Thanks!
Is the engine at operating temperature when doing the extraction? It should be. You will achieve better extraction results as the oil is of lower viscosity.Using a MityVac extractor, the most I can get out is 6 qts, yet my dealer consistently charges me for 8 quarts. Any comments, suggestions, advice?/ Thanks!
Thanks for taking the time to respond to my post. I have used both the Mityvac and the Topsider multiple times but again only able to extract about 6 qts!That is why I like my Topsider - you stick the tube down until you feel the bottom of the pan - I can't speak specifically to your application, but every Mercedes I have had - I6 M103, M119 V8, M272 V6, have all had the 8 LITER capacity. Or about 8.5 qts.
Thanks for taking the time to respond..... I have done several of these top-side extractions and always have the oit at operating temp....Is the engine at operating temperature when doing the extraction? It should be. You will achieve better extraction results as the oil is of lower viscosity.
With Topsider unit , you have to be persistent and patient with pumping . It takes me 15-20 minutes, maybe half hour to do a complete job.Thanks for taking the time to respond..... I have done several of these top-side extractions and always have the oit at operating temp....
I'll stick to what works too thank youI've NEVER and I repeat NEVER used the vacuum method to remove engine oil. I was a dealer for 20 years and we never found any advantage to it. Like nearly everyone is saying, you can't get the oil completely out and the oil drain plug does. I will disagree that the vehicle IS NOT designed for this purpose, the pan has a low area where the drain plug is located.
So, use whatever method you like. I'll stick to what works.
No. I drained it for several hours until it was not dripping any more. Buttoned her up, dropped her and filled with 7qts on level ground. Waited about 15 mins then checked the dipstick.Did you start the vehicle and then let the oil settle?
