Run
from either.Neither is a reliable daily driver.Both rate at the top of the worst models in Mercedes history.Why invite trouble.Or if you have deep pockets,do you mind them getting shallow?
Check out what it costs to repair an sbc,even if you never had a problem the system counts brake applications and triggers a trip to the dealer.
check out how many grey hairs you have if the sbc fails and you need to stop that thing with the back up hydro system.
A few of the issues.More can be found
Recall Reason SERVICE BRAKES, HYDRAULIC
Recall Date JUN 22, 2004
Model Affected E CLASS
Potential Units Affected 143387
Recall Summary
ON CERTAIN VEHICLES, THE ELECTRONIC MONITORING SYSTEM OF THE SENSOTRONIC BRAKE CONTROL (SBC) IS DESIGNED TO MONITOR THE PRESSURE GRADIENT WITHIN THE HIGH PRESSURE LINE OF THE BRAKE SYSTEM. IF AN UNACCEPTABLE PRESSURE GRADIENT IS DETECTED, THE SYSTEM WILL SWITCH, AS IT IS DESIGNED TO DO, INTO THE HYDRAULIC FUNCTION MODE.
Consequence
IF VEHICLES ARE NOT ROUTINELY SERVICED AND HAVE EXTREMELY HIGH MILEAGE COMBINED WITH A HIGH NUMBER OF BRAKE ACTUATIONS, OR A HIGH BRAKE ACTUATION FREQUENCY, THE PUMP MOTOR OF THE SBC MAY RUN OUT OF PERMISSIBLE TOLERANCES, THEREBY TRIGGERING THE HYDRAULIC FUNCTION MODE.
Remedy
DEALERS WILL INSPECT THE SBC HYDRAULIC UNIT, REPLACING IT IF NECESSARY. THE RECALL BEGAN ON OCTOBER 21M 2004. OWNERS SHOULD CONTACT MERCEDES-BENZ AT 1-800-367-6372.
Notes
MERCEDES-BENZ USA, LLC. 2004050014
JUL 07, 2008 | Recall ID# 45292
ELECTRICAL SYSTEM
MERCEDES-BENZ IS RECALLING MY 2006-2008 M-CLASS, R-CLASS, MY 2005-2009 SLK-CLASS, MY 2005-2008 C-CLASS, MY 2003-2004 AND 2006-2008 CLK-CLASS, MY 2003-2008 E-CLASS, MY 2004 AND 2008 CL-CLASS, MY 2008 CLS-CLASS, MY 2004 AND 2007-2008 S-CLASS, MY 2003 G-CLASS, AND MY 2003-2004, 2006 AND 2009 SL-CLASS VEHICLES. A SOFTWARE CALIBRATION NUMBER (SCN) CODING RECEIVED ON THE AFFECTED VEHICLES DURING A RECENT WORKSHOP VISIT WAS INCORRECT. DEPENDING ON THE MODEL YEAR AND MODEL AFFECTED, THE RESULTS OF AN INCORRECT SCN CODING CAN AFFECT A NUMBER OF VEHICLE SAFETY AND EMISSION FUNCTIONS INCLUDING THE FOLLOWING TYPES OF FUNCTIONS: (1) THE FUEL GAUGE READINGS MAY BE INCORRECT; (2) A STUCK FUEL-LEVEL SENSOR MAY NOT BE DISPLAYED IN THE INSTRUMENT CLUSTER; (3) THE OBD SYSTEM MAY CAUSE THE CHECK ENGINE LIGHT TO ILLUMINATE INCORRECTLY; AND, (4) THE SPEEDOMETER MAY BE OUT OF TOLERANCE....more details
Recall Reason ELECTRICAL SYSTEM
Recall Date JUL 07, 2008
Potential Units Affected 404
Recall Summary
Consequence
IN THE EVENT OF A VEHICLE CRASH,
THE ELECTRICAL FUEL PUMP MAY NOT RECEIVE A CRASH SIGNAL THAT IS REQUIRED FOR THE FUEL PUMP TO DISCONNECT AND PREVENT FUTURE FUEL DELIVERY AS DESIGNED.
(That is cryptic for the car may go up in flames)
Remedy
DEALERS WILL RECODE THE SCN FREE OF CHARGE. THE RECALL BEGAN ON AUGUST 30, 2008. OWNERS MAY CONTACT MERCEDES-BENZ AT 1-800-367-6372.
Notes
MERCEDES-BENZ USA, LLC. 2008 070001
APR 01, 2005 | Recall ID# 23534 Show Details
ON CERTAIN VEHICLES, THE SENSOTRONIC BRAKE CONTROL (SBC) SYSTEM MAY PREMATURELY SHIFT TO THE HYDRAULIC BACK-UP FUNCTION MODE, DUE TO DETERIORATION OF THE WIRING HARNESS CONNECTION, OR DUE TO PREMATURE FAILURE OF THE HYDRAULIC PUMP....more details
Recall Date APR 01, 2005
Potential Units Affected 204000
Recall Summary
Consequence
IN THE HYDRAULIC BACK-UP MODE, THE DRIVER HAS BRAKING POWER SUFFICIENT TO STOP THE VEHICLE, ALTHOUGH GREATER BRAKE PEDAL PRESSURE IS REQUIRED AND THE BRAKE PEDAL TRAVEL WILL BE NOTICEABLY LONGER.
Remedy
DEALERS WILL INSTALL A BRACKET AND REPLACEMENT GROUND WIRE TO THE SBC PUMP UNIT ON ALL VEHICLES FREE OF CHARGE. ADDITIONALLY DEALERS WILL INSPECT AND REPLACE THE SBC PUMP UNIT IN SL VEHICLES PRODUCED DURING A LIMITED PRODUCTION PERIOD. THE RECALL BEGAN ON AUGUST 8, 2005. OWNERS MAY CONTACT MERCEDES-BENZ AT 1-800-367-6372.
Notes
MERCEDES-BENZ USA, LLC. 2005070007 & 2005110
AUG 07, 2003 | Recall ID# 5562
STEERING
ON CERTAIN PASSENGER VEHICLES, THE NUT ON THE BOLT WHICH CONNECTS THE STEERING GEAR TO THE STEERING COUPLING MAY NOT BE TIGHTENED CORRECTLY....more details
Recall Reason STEERING
Recall Date AUG 07, 2003
Potential Units Affected 554
Recall Summary
Consequence
THE LOOSENING OF THE NUT COULD RESULT IN A SLIPPING OF THE CONNECTION OVER TIME,
INCREASING THE RISK OF A CRASH.
Great piece of work,those W211's:thumbsup:
:bowdown:
