What mm Offset does a 2000 E320 need for wheel size. Also, if you increase from 16" to 17", does this change the offset?
What other models have the same offset?
Thanks for your help.
BenzWorld Tire & Wheel God
it depneds on the wheel width not diameter
e.g.
17x7.5 ET35
18x8 ET31...
e.g.
17x7.5 ET35
18x8 ET31
Re: it depneds on the wheel width not diametere.g.17x7.5 ET3518x8 ET31...
Thanks. So if the factory wheels are 16" x 7.5", are they also ET35???
Do you recommend staying at 7.5?
e.g.
17x7.5 ET35
18x8 ET31
[/quote]
the OE wheel for a 2k E320 is 16x7.5 ET40...
2003 vs. 2000
Luke,
Thanks for the help. I get to South Bend about 4 times a year, will need tires this summer, so will check TireRack out.
I do have one last question. Will the rims from a 2003 E320 fit my 2000 E320? Any issues? Is the offset the same?
Thanks again for your help.
