Car was on the last leg of a 300 mile trip when this noise began. It varies with RPM. Oil is clean and full (just changed today). Sounds like a belt noise? Maybe some accessory bearings going out?
That looks like the one, thanks!This version looks a little different. Seems you have the later version and you may have to remove the viscous fan clutch then swivel the tensioning pulley to get that belt off.
http://www.w124-zone.com/downloads/MB CD/W124/w124CD1/Program/Engine/104/13-1200.pdf
I guess it is possible to get a wrench on it without removing the fan if you have the right one. Anyway you have to make it swivel by turning it clockwise to remove tension from belt.
Glad you found your problem for very little money....Local shop that installed 2 new bearings for $35 in 30 minutes. Yep...
