E320 CDI Timing chain stretch.
1 reading
11K views 2 replies 2 participants last post by  Rossafuss
I decided to check my timing this weekend between camshaft drive gears and the crank. After 427,000 miles, figured checking the original chain for stretch would be a good idea. :D
I was able to get in and align the drive gears to check how advanced the crank was from TDC. theres a small plate covering the gears and sprocket slightly above the HPFP. Here's a video on how i did that:
I calculated how far the engine is out of time, its about 15 degrees. (The HB TDC mark is about an inch from the TDC mark on the timing cover.
15 degrees is pretty significant, so i'm going to end up changing the chain and guides here soon, ill do a full writeup on that for you guys. The job should be much easier than the older IDI Mercedes diesels, as all the guides are easily accessible when the timing cover is off. As some of you know, there is only ONE sprocket going to the camshafts, the second camshaft is gear driven from the first, and there is no noticeable wear on either the sprocket or gears.
I know my engine has quite a few more miles than almost everyone else on this forum, but i would still recommend checking the timing for anyone over 200k miles.
Very interesting and informative...thanks.
It would be interesting to know how well cared for the engine was (I'm mainly thinking oil changes) prior to your ownership.
#3 ·
The car was dealership serviced up until about 390k miles, then there was a "grey area" for service for about 12k miles. I knew that and took the risk when I bought it. I changed the engine, transmission, and power steering oil right after I purchased the car.
When I had the cover off this weekend the inside of the engine was incredibly clean. Like mind bogglingly clean. I only had a glimpse at a small section of inside of the engine, but I was very impressed with what I saw and how well synthetic oil has protected this engine.
For any DOHC diesel engine to have a timing chain last 400,000 miles is remarkable in my opinion. And to be honest, it could probably go further without replacing the chain. I'm changing it for preventitive maintence, not because I'm having any problems. The engine still runs fantastic.
