Replacing the injector seals and the threads for the injector seals are stripped out. Someone in the past had already resized them to a larger bolt, but those are stripped out as well. What should I do from here? I was thinking about melting down some aluminum rod, filling the hole with that and then tapping in new threads. Would that be a viable solution?
2005 Mercedes CLK320 2008 Mercedes E550 2013 Mercedes E63 AMG
That is an appropriate repair. Keep in mind that the head is an alloy so pure aluminum will not be as strong. The best I have seen is aluminum welding and then retapping.
Moderator
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, 2005 E320 CDI, and 2006 S500 4Matic
^^ General idea is sound. In this particular case, I would actually recommend a Time-Sert, which takes up even more space, given that someone apparently had widened the hole earlier. Why people do this instead of a proper repair, I wish I knew. OP, you can recover from the previous owner's apparent butchery.
W212 350CDI -09 W219 320CDI -07 Ex:W220 320CDI -01 Ex:W210 270CDI -01 EX: W211 320CDI -04
Time-sert is a good solution, if only current enlarged thread is not already too large.
