mercedes e320 2000
hi all
one of my front foglights went out
wondering what the bulb is called that is needed to replace it.
and how i install it is another question.
cant seem to find anything regarding replacing foglight bulbs in manual.
thanks for any info
10 GLK 350 4Matic
Here is what you'll need:
H7 - regular headlight
H7 - hi-beam headlight
H1 - fog light
1156 - turn signals
H6W - parking lights
Good luck
mercedes e320 2000
is there a way to get to the bulb so i can replace it?
seems that i have to pull off bumper.
Underneath the bumber area just behind each lamp is an access panel. I Found a cover for one of mine but my arms weren't long enough to reach it from above. A friend of mine found the little door under there.
Brian - Yakima, WA
2000 E320
2000 E430 4Matic; 2008 S550 4Matic; 2014 E63s
Use a coin or large screwdriver to open access port under the bumber. If you have small hands you can remove the bulb (H1) without removing the entire assembly - otherwise its 2 screws to remove the fog light.
In some cases, like mine, the job is not as simple as it would seem since the harness has been know to melt at attach itself to the existing bulb. See thread at http://www.mbnz.org/forums/forums/thread-view.asp?tid=1195742&posts=3&hl= for additional info on replacement harness if this is a problem for you.
