1 - 9 of 9 Posts
' 91 350sel, '12 s350, '18 144 sprinter, '08 sl550
on 1999 e300 diesel....
no power, earlier had mas sensor code, new sensor cleared that, but now the 1470
found post on possible problems..
the vacuum transducer ? y31/5 ... anyone with a part # on that ? cant find on part..
thanks
Banned
1999 E300 TD
thanks
First clear the code.
Our cars have two of them(Y31/5 and Y31/1) on on the right and left side. On my 99TD standing in front of the car, the left one(Y31/5) is attached to the intake filter housing. The right side is close to the EGR valve.
In any event you will notice three hoses (vacuum and intake) on Y31/5. Before you purchase a new one make sure all the hoses are intact, if they are remove the one lower hose and try to start the car------what happens??
pulled vac hose off the bottom of passenger side vac valve, car started no problem, but still in limp mode on low end and high end.........
thanks for the help
but i didnt clear codes........dont have obII
can codes be cleared another method ?
There are places that will read and clear the codes for free (like AutoZone, Advanced, Pep Boys, NAPA etc.) And you can buy a decent OBD2 scanner from any number of places for about $50 to $75.
Banned
1999 E300 TD
Clearing the code before you unhook the bottom air in hose on transducer is critical. Get the code cleared then unhook the hose.
FYI both of the transducers on the 606.962 have the bottom air in hose. If you follow the hose to the end you will see a small plastic ball. That ball is a replaceable filter that filters the air in. If its clogged, and it is difficult to determne, it will produce a fault. Of course if you still get a fault with the hose off than my guess is that the transducer is bad, but you tried.
Good luck
any particular obd2 scanner to buy ?? autozone tried scanning , could nt .. and they said they wont reset codes.:surrender:
so i ll buy one on fellow members recommendation
thanks !
Banned
1999 E300 TD
Just a curious question-----If you don't have a scanner---how in God's/Allah's name did you come to the conclusion that P1470 was is or otherwise present!!
Is this a test question!!!!!!
hope i get the answer right :eek:
local shop scanned it, he s not big on the diesels and doesnt want to kill me with hourly diagnosic charges. given him plenty of other work i cant do...
how d i do ???
Banned
1999 E300 TD
You had me worried for a minute.
Sorry your guy has difficulty with diesels. If he took he time to compare them the diesel is far simpler to diagnose. Very straightforward.
Oh well get a cheap scanner, clear the code and you will be able to quickly test the vacuum transducer. Good luck!
1 - 9 of 9 Posts
