1988 420SE, 2002 C180 Kompressor, 200 ML320
Hi guys
Servicing a friends 2006 E280 CDI next week and the diesel filter needs replacing.
Done it many times on older W124 models but not this engine,
Does the fuel system self bleed by turning the engine over as on the W124's or does it have to be bled manually and if so is there a manual pump built in or do you have insert one for the job and removed after bleeding?
Many thanks
Many thanks
