Hi everyone
I have Mercedes w124 e220
I have a problem that when i lock the car the gas door won't close
Could anyone help me to slove it?
Thanks.
Most likely culprit is a torn or worn vacuum element. You will have to remove the trunk lining to access the vacuum element.
Once removed, you can test it using a vacuum pump such as a MityVac and see if it holds.
2014 G550, 2000 SL500, 1995 E320 Cabriolet, 1980 TR8
If I remember correctly, you need to close the gas door before you lock the car.
Reactions: tuttebenne
It's just a little pin that throws when you lock the car with the vacuum pump. It's almost always that vac pod right there inside the rear compartment. Easy to replace....
Kevin
It's just a little pin that throws when you lock the car with the vacuum pump. It's almost always that vac pod right there inside the rear compartment (sorry, that's for the TE). Easy to replace....
Kevin
