W210, W211, W163
Really need some help. I am trying to get the car in dyno mode but must be doing something wrong.
It's a 2003 E320 (W211)
Have the display showing outside temp. Turn key to position 2, than off, than 1, than press reset x3 fast but nothing happening.
Also tried a few other ways but no success. Saw a couple of videos on how to do it, but still no luck.
When I try it I see the SRS light flash once but nothing changes and I don't have access to the dyno menu.
What am I doing wrong?
Banned
2006 E320 CDI
Turn the key to position one > change to temperature display> press reset three times and you will see model of the car displayed plus oil quantity and other things> press arrow up ones or twice an you will get to circuit 15 on/off display.
Perhaps it is not there at all? If I remember right, early W211 models did not have it, at least did not have the option to show the battery voltage.
W210, W211, W163
So I tried that as well and it didn't work. I am wondering if the car can be put in dyno mode via the cluster.
When I try the procedure the SRS light flashes once but nothing else happened.
This W211 with production date 08/02. Does anyone know if all the W211 have this or not?
