07 R 280 CDI
My last car, a CL 500 (2002), had problems with the dynamic seats. First they changed the air pump, that didn't help. Then they changed a plastic pressurebox, then it was solved. Hole operation costed a whopping 7-8000 dollars!!!
Now I've just bought a 05 CLS 350. Same problem. The operation of the seat seem to start, but cuts after just a couple og seconds. If I press the massage button, first time the red light stays om for 5 seconds and then switch off. If I try again, the light just start blinking and nothing happens.
Is this a known problem, or am I just unlucky? Anyone had the same problem?
hi my 05 55 amg does the same i have found the fault it has to have a new seat pump and modifyed pipes as the old ones get to hot and melt
CLS 500 '06
My 2006 cls 500 has dynamic seats, but everything works absolutely fine. Allthough I had heard from my mechanic that in the past he had repaired a malfunctioning driver seat. Does it give you an error message in the cluster or the STAR diagnosis?
07 R 280 CDI
No errors anywhere. It's probably a leak, since it starts up but gives up after some seconds. Leaking airbags in the seat is quite common my mecanic says
