Mercedes 96 C220
I recently had a problem with my ac,side vents blew hot,while middle stays cold.I did my research and checked my duo valves,I found that the rubber in there was torn and no good. Im pretty sure thats the problem with the ac, so my question is Where can I buy that rubber piece?
95 C280, 89 300E, 94' E320 Coupe, 91' 560SEC
So which item is it that you are referring to item **65** or is it **125**.
You can order them at the Dealer ship. I'd say 1/4 of the time the dealership has the parts at around the same price. So I would give it a shot.
Mind you this parts list says 202.028 which is for the c280/c36 but the 202.022 is the same part # for the listed
You can order any part imaginable, from a cylinder head to a washer in the door lock and Stickers/ clips. Everything in you car is comprised of parts and all these parts need to come out of a batch/bin during assembly. So to keep inventory, part numbers are assigned to everything.
I would however, before ordering the part # (A 140 987 01 40), consult with your MB Parts Adviser to confirm. They are a wealth of info as every part has crossed there path as well as seasoned Indy mechanics and volume of parts to have an idea of what mostly has to be replaced from chassis to chassis.
