What's inside the lighter receptacle? Car is an '02 E320 wagon.
No, I don't smoke. And yes, the fuse is fine. But, our GPS won't work, and the lighter wouldn't heat up when I tried it instead.
Using a test lamp, I found 12V inside the receptacle (with the ignition on). But only at the head of a rivet in the center bottom of the lighter receptacle. The removable lighter won't make contact; neither will the GPS adaptor.
Is there something missing from the inside of the receptacle? Do I need a new receptacle, or just the (imagined?) thingie that's missing?
