1 - 20 of 21 Posts
2000 SLK 230 LE
Anyone know of a good (and inexpensive) way to change the single exhaust tip to a dual? Can you swap out the tail section of the exhaust of the 230 with a 320 or is there another way?
I mainly want to do it for looks since I understand there is no major HP difference with changing exhausts and I already like the sound of the stock resonator.
Thanks.
2003 SLK 320
Do you want two tips on the same side of the car, or one tip on each side(or two on each side for that matter)?
2000 SLK 230 LE
Discussion Starter · #10 ·
slkpwr,
Yes, exactly like that. That is the look I'm going for. I thought the 32 rear muffler wouldn't fit on 230 since the piping is different.
I may have been mistaken on the 320. I thought it had dual pipes but I guess I was wrong.
2003 SLK 320
The 320 does have dual pipes, but they converge into one exhaust tip.
SLK 230
I also want the "twin pipe" look on my 230. someone suggested getting 2 oval ones and putting them together, but that won't fit into the hole in the bumper, would require a body-cut.
I'm looking for a straight replacement of the single oval chrome tip, really i need a twin-tip !
2000 SLK 230 LE
Discussion Starter · #13 ·
SLK 230
Hi cmorosco..
We are looking for the same cheap mod !
I looked at the link you gave, and for me the tip for the S-Class W220 is what we are looking for, eg: two tips attached to one pipe. (SLK has only one pipe from the back-box). However, I'm not sure if it will fit into the cut-out in the bumper. But its the right application, if we can find the same for the SLK then it'll be perfect.
2000 SLK 230 LE
Discussion Starter · #16 ·
So the S-Class ones are $360 a set and you have to buy them together. They come as a Left/Right set but I think the left one is the only usefull one for an SLK. That's too expensive for me. I'm better off buying a a whole new rear muffler from Remus for that price.
01 SLK 320 MT6
BlueBenz - 1/31/2005 8:07 AM
Thanx Krill...
sadly nothing for the SLK :-(
I think trying to "butcher" the tips they sell to make it fit could be quite tough !
cmorosco, mentioned S-Class tips - that's the same for 1/2 price.
There is still a chance that S-Class tip will be a direct fit, but you need to find a store that will take returns if it's not.
1 - 20 of 21 Posts
