I've had the Window regulator and motor replaced on the driver's side front door. It seemed to work fine after the repair.
The battery then died and I replaced it. Now the window won't go up unless you hold the switch (won't go up with on touch).
Did the battery replacement cause this and require some reprogramming, or did the window repair fail/
Thanks.
Steve
