2008 ML350; 2001 SLK230 (traded in)
When I have the driver's side window down, I can hear the window rattling away in there (doesn't happen when it's up). How do I remove the inside door panel so that I can see where the rattle is coming from? I'm a bit leary only because there's an airbag in there and I don't want to accidentally set it off and land 50 feet away....ouch.
Golf R32 / Prev R170 SLK
You wont set it off.
http://www.benzworld.org/forums/search/query.asp?keywords=door+trim&searchforumid=26&author=&days=&action=search
Remove something like this from memory.. You will see where to undo or release as you go.
Pull out airbag label. Undo screw. Clip off inner pull handle cover. Undo screws.
Remove corner embelishment.
Pull trim off from bottom edge. If you have one slide a trim tool around pop serts.
Airbag is fixed to door framenot trim.
Good time to reglue loose trim panels as well whilst off.
I repainted my door pull handles last time with VHT aerosol grey trim paint.
Bazzle [8)]
