1990 Mercedes 560SEL
As seen in picture, the driver's side carpet, that is closer to the door, is coming out. I tried pushing it in with a screw driver, but it won't stay there. I probably have to remove that plastic holder (not sure about the correct name of this part). Then put the carpet back in place and the holder on top. How do I remove this plastic/aluminum thing? Do I just pull out? Are there any hidden screws or special tools for this? Please let me know. Thanks.
SuperModerator
1986/1990 W126
Yup its just clipped on. Hook your fingers under on end of the plastic piece and pull upwards firmly. Then you can tuck the carpet back in and the piece clips back down with firm pressure.
w126
Hidden beneath that sill plate are(or should be) a couple of plastic pins that hold the upper edge of the carpet in place. You can probably see a couple of holes for those with the carpet piece pulled out like that.
