1998 S420, 1985 560SL, 1993 SAAB 900 Turbo Vert
Ok all,
In the past week, I have been getting an annoying click and a small amount of movement from my drivers seat. Now I am not a small person by any means, 6 ft 3 and 280 lbs, but this is driving me frickin nuts. I don't really notice it till I put on the brake and it is like it clicks down ever so slightly, anyone else have this issue and what is the fix as it is driving me crazy. I know it is something little but I take perfect care of my car, and don't want this to happen anymore.
Thanks!!!
'14 E350, '07 CLK350, '01 SLK320
Mine does the same thing. I believe it is caused by worn gears in the seat adjuster mechanism. I remember reading somewhere that replacement gears for this thing are heinously expensive, so I have forced myself to deal with it for now. One of these days when I have nothing better to do I will tear into it and see if I can tighten it up.
You can try adjusting the seat cushion length in or out a bit and see if that helps.
1992 & 1993 300SE
Seat Movement
Noticed same thing in my 300SE..seat seemed to rock, not much, but noticeable.
I poked around and saw it was going to be a MAJOR job getting into the gearing...but, I did alleviate it some by raising the seat straight up...still rocks, but not as much.
