Looks like I need to get the driver's door panel off to repair or replace the window regulator/motor. Any tips?
Sunroof moves just a little bit right now. Tried putting a heavy lube along the tracks and am letting it sit overnight.
AFARR
1991 W124.128
Hi,
remove round door locking knob on top of panel
pry out little plastic piece on top of inside door handle with a thin screw drive or knife.
remove bolt on top of door handle - 10mm socket required
push forward rectangular/trapez shaped chrome piece and remove away from panel
disconnect wire rod (to door lock) from inside door handle.
push up door panel about 1 11/2" and move away from door
- be careful with the inside plastic brackets/clips which lock into the door. Have a glue gun handy as most likely clips have to be reglued to the door.
Actually very easy to r&r door panel. Hope, this helps
