1994 E420
The motor runs and I hear a click click click but the window won't move. The story: About a year ago I pulled into a store and parked on a very windy day. As soon as I opened the door the wind whipped the door out of my hand and hyper extended the door and I heard a pop. After that the window always had problems, it would go down to a point and then get stuck, make a bad sound and continue all the way. Interestingly when the door was open it would work just fine :surrender:
So now it just wont budge.
Any ideas? Is it a real PIA to open up the paneling to take a peak at whats in side?
so the wind broke the check-strap?
Or was it broken prior to the event?? Sounds to me like you'll have to open up the door and see what's up. You need to replace the check strap anyhoo.
Michael
1994 E420
Thanks for your reply. Everything was fine prior to the event. Any suggestions on opening the door up? I don't even know where to start :eek:
Immoderately Caffeinated/ Vintage Moderator
T5
