Using either a plastic wedge or a covered flat screwdriver, you can pop off the triangul...
Using either a plastic wedge or a covered flat screwdriver, you can pop off the triangular shaped black plastic cover on the inside of the door. Remove the cover and you'll see the screws that hold the mirror assembly onto the door.
