Hello, new to this forum and also new owner of a MB car.
Recently bought a new GLB 220D and have experienced many occasions that the driver screen behind the steering wheel failed to turn on and stayed black when I started the car. The other entertainment touch screen was working normal and the car engine can be turned on and can be driven as normal. Just the driver screen stayed black throughout. I find that I have to turn off the car or lock the car, wait 2-5 minutes for the MBUX system to completely power off and then unlock or press the start button, only then the driver screen can be turned on as normal.
Also, I notice that whenever the MBUX system is on, there is always a loud fan-like and electric pulse-like noise coming from behind the steering wheel. The noise level is so loud that can be heard even after turning on the radio or the engine.
I have already taken the car to the dealer once, they said the noise is 'normal' and they updated the software to resolve the black screen issue. However that didn't work. I still experience black screen from time to time.
Have anyone had similar experience with the black screen and the high level of noise in you car?
Any advice of the cause and solution?
2690990
1998 MB E300TD, 1997 MB E36 AMG, 2001 MB E55 AMG. 2011 BMW 335d
You have bad IC module. Get the dealer to replace it. Record with phone every time it turns black, and I mean every time.
Then show to dealer. Call corporate if necessary.
Thanks for the reply. What is IC module? Is it the screen? And does the IC module relate to the noise issue?
IC is instrument cluster.
It's tied to the IC. It's overheating.
