1 - 20 of 29 Posts
2002 CLK 430 & 2001.5 Chevrolet Silverado Duramax EC/LB LB7
I need a new driver mirror for my CLK 430. Where can I find a cheap one? I heard from the dealer that the OEM mirror runs somewhere in the $300+ range. Is there a mirror that is cheaper than that? I don't really care if it is electrochromatic or not.
If you have any info on this I would greatly apprieciate it!
Thanks!
Zack
Hopes & Dreams
There was actually someone on this forum who was selling theirs, it was a recent posting too. Check out the first few pages of the forum or search it and you should be able to find it.
Hopes & Dreams
Wait, do you want the entire assembly or 'just' the mirror?
Upon reading your original post again, I'm going to guess 'just' the mirror?
...like I said in the other thread, I'm tired. So I'm not all here.
2001 CLK 430
Not sure about the Velcro comment, I never saw anything like that in there. I had to replace my mirror last year. I just went to an Auto Glass place, gave them the old broken cover, and had them cut a new piece of glass to fit. It was $30. I put the new glass in the old cover, then hooked that up to the motor mount piece.
A few months later was in an accident and got the mirror replaced under my deductible.
To put it on... Plug in the wires. Tilt the circle plastic piece (#2) all the way down, so the top is easier to get to. On the back of the mirror (#3), there are two grooves on the bottom that will fit with the two notches on the bottom of the circle plastic piece. Match those up first. On the back of the mirror, there is a wire at the top. That wire needs to snap over the notch at the top of the circle plastic piece. I used a pocket knife or small screwdriver to hold the wire up while i put the mirror on the notches and then let the wire snap into place. It took me a few tries before it worked. Hope this helps.
To take it off... I would think that you would need to somehow pull that wire up, maybe with a small hook or something to release the mirror to take it off.
Mercedes-Benz CLK-430
if you are interested both ways are possible ebay, and paypal, ebay ill put em on ebay and you buy em, or ill give you my paypal account and you make a payment to my paypal account.
1 - 20 of 29 Posts
