The window lock button on my '07 ml350 is stuck in the lock position and wont come out. Now I am forced to replace the entire switch cluster in the diver's door. Does any one know how to remove it? Does the entire door panel need to be removed or does the cluster just pop out? Any help is appreciated.
2008 ML320CDI Iridium Silver/Black, NAV, P2 pkg, Sirius, Harmon Kardon. Active Bi-Xenon
I had to have mine replaced also, I believe you have to remove the door panel. Mine was done under CPO, so I dont know the details. But same issue, window lock button stuck down
