I have a 96 S420 and finally got around to trying to figure out my driver door unlock problem (with the key it wont do anything in driver door), so I finally got panel off and now I can hear a hissing sound when the unlock is supposed to happen, does that mean a leak? are the 2 little plastic hoses the vacuum lines?
I guess I need to feel around and see if I feel the leak?
any ideas/suggestions?
also what do i look for since the key doesnt do anything in the door? It does what its supposed to do when i do it from the trunk.
thanks for any help!
Brian
Outstanding Contributor Always Remembered RIP
The vacuum element has split inside, they just clip onto the actual lock, I have just got one fro my trunk lock,only £13 in the UK.
i you have the close assist the will be 2 actuators, you only need the locking one. you need to change it as soon as possible or the PSE pump will burn out if it runs for the max time
you were right...
The actuator did split...i was able to fix it though..all back up and running!
i was also able to take the door handle off and fix the key issue...the pin was not attached to the handle anymore so i connected them back and all good....now if i can just find a passenger mirror i would be golden!
thanks,
thanks,
Loads of them over here, but the wrong side for me in the UK, I need one as well, as they are on opposite sides we will have to do a swap
Hi bdepew, you look pretty new! Welcome.
Depending on what is wrong with your pax mirror, and your car is Left-Hand-Drive, I might be able to help.
Our car is a '97-S320. I have a used but fully functioning (don't know if it's original) right-side pax-side mirror, but inside parts and heated-mirror only, which includes the very-worn triangular rubber gasket that goes between the door and the mirror. Only the gasket was going bad, but I couldn't find one, and it didn't need a new cover, so the smallest "piece" I could buy that included the gasket was an almost-complete mirror -- no new cover. This also has the motor for folding flush. The wires are very good (left ones weren't). It does NOT have auto-dimming. I don't think any pax mirrors have heating AND auto-dimming, nor auto-dim only. It's nice to have one mirror that doesn't dim. In case yours does have that, the 2 variations ("heated" -vs- "heated and auto-dim") have different connectors, so you would lose both functions using mine.
Most of my left one's wires had cracked insulation and green-powder on the exposed wires (and a severely dark mirror due to bad auto-dim fluid). Sometimes movement was erratic, and memory function was iffy. I read this could be due to bad insulation, even on newer 140 models, and fortunately hadn't seen any smoke yet, as others have reported. Initially I put some "Liquid Insulation" on them, and it worked perfectly. After approx 6 mo., I had the money to buy the inside-only parts for both sides...all to get a good rubber gasket. About a month ago one guy was seeing if he could get just a new gasket -- I'll check for that. A couple of connectors hide behind the gasket even when the mirror is folded back, so the gasket protects those from rain/snow/dust/dirt, but alas, not the inside parts. The motors are sealed fairly well anyway. But if you don't have to, I'd suggest only folding them back on a non-rainy/snowy day. They can be stolen easily if they're folded back, too -- only 3 screws and pull apart 2 connectors.
so....
So were you saying you had a passenger side mirror? folding?
Hello! I am having i think the same problem as you. I can lock but not unlock the driver door when i press on my key pad. All the other doors lock/unlock with out a problem. All of my closing assist works on all doors. I do notice a hissss whenever i sit down on the driver seat and sometimes my trunk will open if i sit too hard. At first i thought it might be the lumbar bag but the bag is fine. The only thing i can think of is the lock actuator. So i looked on ebay for a vacuum door lock actuator and this is what i found.
Vacuum Actuator Door Lock Left Front S500 Mercedes Benz W140 Used Part | eBay
Would this be the correct part to replace?
