1 - 8 of 8 Posts
w210, E320.
Hi,
I did the passenger engine mount wasnt' too bad. I'm doing the drive side engine mount. I moved the compressor out of the way and I'm underneath the car. I can feel the top bolt but I need to know what is the best tool to get that bolt, any clues anybody?
usaims
'01-E320 & 02-ST2
I used the box-end of a combination wrench to break it loose; the stubby ratchet is too short for that. Remove the bottom bolt from the mount and jack it up an inch or two, that will provide a little extra clearance to get a longer wrench in place.
Please click user CP and add your vehicle (including the year) and location to your profile. It's useful information.
Dallas, Texas
Set of two 16 and 17 makes it easier. Since wrench like this works as torque multiplier you use only 3/4 of specified torque.
I have that exact tool. I can get the tool on the bolt but I can't loosened it by hand. When I try to attach a ratchet to it, the tool comes out of the bolt.
I have tried getting to the the top bolt with the tool already attached to the ratchet. Look at the pic, sometimes I can get a grab but turning it is difficult.
Torque = Force x Length.
You can't undo the bolt with your tool.
You need 1 straight closed end ratchet wrench. One end of the wrench on the bolt, thread the other end with a pipe or conduit, find a support/leverage on the engine block.
The conduit is $2 for 16 feet at Lowes or Home Depot. Cut it to the appropriate length for the job.
Dallas, Texas
Tool you have is too short. Tool in the picture is 3 inches long. Idea is to attach long 3/8 extension then ratchet and attack it from below cross member. Ratcheting wrench works too but you need help of the prybar.
W210.265/2001, W220/S500/2000, Porsche 997 C2S/2006, GMC K1500/1992
I failed at the point where you were. But I read another post, the guy has to remove the hydraulic pump in order to get extra space, but he got a wagon just like mine. If you have a regular E320 sedan, you should not ran into space issue.
1 - 8 of 8 Posts
