1 - 13 of 13 Posts
what's up everyone?
i was driving all day yesterday in NY while it was pouring - towards the end of the day, while i was driving home, one drip of water, from the corner where the top connects to the windsheild, fell on my hand...
has that ever happened to anyone???
what should i do???
thanks
R
2005 SL600; 2007 ML500
Had the same thing on my 2005 SL600. Had to take it to the dealer and have the seal fixed. Had the trunk leaking problem as well, and they fixed it all (crossed fingers).
1995 SL 500 2017 AMG GLC 43
Had the same corner leak in my wife's 05 SL. Dealer replaced the whole seal under warranty. Good as new.
It's a one day thing. Make an appointment. Question, have you noticed that when you apply the brakes at less than 1-3 mph, the steering wheel pulls to one side or the other? If so, that is also an issue they will correct under warranty by replacing a set of bushings.
Here's the part number for the bushings that they replaced. 211-333-29-14. The mechanic removed both front lower control arms and replaced the bushings. No more wheel twitch.
Outstanding Contributor
2003 SL500, 2003 SL55, 1998 SL500, (2) 1991 300SLs
I need this done for my car, Lee. How many hours of labor did this take? Were the replacement bushings the same part number?
According to an M-B bulletin that particular "hydro-mount" bushing you mention can cause a knocking sound when going over a bump or applying the brakes. The solution mentioned is to substitute a conventional rubber bushing P/N 211-333-10-14. I'm curious to know if they installed this substitute on your car...
The bushing P/N 211-333-10-14 has been replaced by the part that Lee mentioned: 211-333-29-14. I brought my pair of torque arms to the dealer and they charged me 1-hour of labor to install the new bushings in the arms. I believe the dealer would have charged 2-3 hours to remove and replace the torque arms. It took me 1:02. It was easier than I expected it to be...
The bushing issue is one that I am involved in right now, I had what I thought was an motor oil leak, much oil on the garage floor. The dealer upon inspection, said that it was the oil filled control arm bushings that need to be changed, I could not beleive that the bushing could contain that much, dirty appearing oil, they got the after market warranty co. to approve the repair last week, I then got another call that the sub frame bushings also needed to be changed in order to align the front end back up. took a few days to get warranty co to cover those, much labor 6hrs. to change "sub frame" bushings. All this bushing replacement on a car with 20,000 miles, can it be? I see that there is a non-oil filled bushing to be used in place of the oil filled. Has anyone else been down this road?
Bobterry99, can you post or send me the link for the M-B bulletins, I would like to find it to review bulletins, I have 3 M-B cars and it never ceases to amaze me what chronic problems there are with these cars.
The only source for M-B bulletins that I know of is www.startekinfo.com. Access costs about $20 for 24 hours.
Bob,
I felt this issue while driving the car. I recently ordered the R230 DVD and found the issue listed under the service bulletin section. It clearly states that they original bushing are too soft and need to be replaced by the stiffer ones I quoted in my orignial message. Time spent replacing them was quoted at 1 1/2 hours. I have a good relation with my dealer and the mechanic so I'm able to go onto the floor of the shop to watch any work performed.
1 - 13 of 13 Posts
