Clk 350
Hi guys
I hope you all had a good holiday season.
I have a code coming up relating to an ageing o2 sensor downstream of my left catalytic converter.
Po515 left o2 sensor (after twc) ageing po159
I have then had another code pop up a few days later saying the left cat efficiency is insufficient.
0946
Is it likely that a failing o2 sensor is the cause of the ecu thinking the cat isn’t working properly?
Is the sensor replacement an urgent job? Can I wait until the weather is a little better :)
Can the failed sensor do any damage?
Many thanks
Jae
· Banned
2005 Mercedes CLK320 2008 Mercedes E550 2014 Mercedes E63 AMG
With the downstream sensor failing, I would recommend changing all four. Use a name-brand sensor and not something for $15. That is my suggestion.
You cannot trust the codes until the sensor is reliable. Hope this helps.
