1998 E430 V8 , 1981 240D DIESEL
I have a double din wood trim piece I installed and I do not know what the pin out is for this connector. it has 4 pins and goes into the multiple switches on top of the double din trim piece. I have heated and vented seats and headlamp washers, rear seat headrest recline, hazard light, and door lock switches. Can someone give me the pinout for 1-4 pins. Thanks
Banned
1999 E300 TD
Overwhelming to say he least!! However to greatly simplify the help issue. Just do this for me: Look at the connector, each pin is numbered----The question is---- what color(s), by pin number, are the wires(connector) in question?
And don't forget to include the VIN as there have been numerous changes!!
the red/green wire is pin 1, black/white is pin 2, black/grey is pin 3, and purple is pin 4. my car is a 98 e430. i am retrofitted double din with a comand hu and heated and ventilated seats. i do not have the vin from the car that is came from. do you still need my vin for my 98 e430?
Banned
1999 E300 TD
I regret to advise that I have not been able to locate the applicable wiring diagram.
Hopefully one of the moderators or others who have access to WIS will be able to help you. Good luck
