Mercedes S320
Hi Guys
I have noticed some of my door seals are coming out of my S320, nothing major apart from the sunroof not closing know because of a loose seal :( i got the car garaged thank god. Has anyone used any product that can glue the seals back to the car permanently
Thanks in Advance
92 500SEL to 01 E320T current 2014 lexus LS460
I would think door seals can be re glued with weatherstrip adhesive. I have repaced the moonroof seal on my 92 it is a a press fit. Expensive, yes , there is an up and down, put the corners in first and then work it all around. I had a body shop attempt it after refinishing a corner. It was a disaster, they could not get it all in so the started to cut it. The bottom line was I said get me a new one, and i will installl, a wallpaper seam roller helped.
